I’m staring to notice a few things here that prove the leveling or adjusting of the z offset does not really do anything,
- if my prints are not “squishing” the filament when printing, lowering the Z does not help.
- when printing, it shows .3mm if I change the offset at any time this is not effected.
- Using the save or not, does not seem to make any difference.
- The printer acts like it level every time before it pints anyways. Do I need to turn that off some how?
- If I add a washer between the tip and the block to intentionally offset the Z in a bad way, I can not correct the issue by adjusting the z using the leveling process.
It’s like this process does absolutely nothing.
