How do I unload the filament from the extruder when I am done with printing?
New SV06 user here. I searched for an answer, but was unable to find one.
How do I unload the filament from the extruder when I am done with printing? So far, the only way I have succeeded to extract the filament is to futz with the “Change Filament” command.
While I was researching, I learned that the Prusa has an “Unload Filament” command. Is this command available and I am just missing it?
Thanks!
Is this helping?
I am guessing that there must be a way to enable “Unload filament” to appear in the menu. I will see if there is a way to access this feature.
maybe you can write this one line of gcode in a file, store it on the SD card and then just “print” that file. But the easier option is to get pronterface or octoprint etc. and just send the gcode manually.
You may want to add the following lines to the beginning of your custom END G-CODE in your slicer iot retract filament:
G91 ; Relative positioning
G1 E-17 F1200 ; Retract 17mm
G4 S3 ; wait 3 seconds
G1 E-50 F2700 ; Retract 50mm
PS: Edited iot add a few seconds waiting time for filament to cool down
This sounds like a great idea! Thanks!
Prepare->Move Axis->Move Extruder->10mm then adjusting to negative worked for me
