Helpful Tip for those getting new sv06 Ace Plus
Just wanted to throw this out there for those who get this in the mail. It was probably more obvious to others but I missed it for a while. This is my first 3d printer.
The only foam visible right off is the larger foam rectangle in the photo, which I removed like the instructions say. Later, after having issues, I found the two small foam blocks wedged tightly between the bed and rail/belt on the Y axis. To some it might not be so obvious.
Yes. Sovol listened. This problem was very common on the SV06 ACE and now Sovol has included a note.
As you say, common and even systematic problem.
I’m such a dummy. I took out the block and at first had those two little squares still wedged in there. AND THIS WAS AFTER WRITING THEM FOR CLARIFICATION
