I can’t pin down why this happens but occasionally after a successful print I’ll try to home or use the QGL function and the gantry will just pile drive into the bed. Sometimes I get the error in the pic on the left side in red and sometimes not. I have been turn off and back on the printer after each print as a way to mitigate this issue but it is still occurring. I have beds that had the black coating stripped off due to this.
The message in your console about the LDC1612 refers to the eddy probe controller. I’d check the cable from the tool head to the eddy probe and perhaps reseat it at each end.
This is the flatcable of the eddy, open the connectors and reseal with hot glue. You also can upgrade to a Eddy Duo with usb. Because after a few times the stock connectors will broke.
So, I opened up the print head and removed two screws. One short screw holds the eddy current circuit board in place and the second holds the hole bracket in place. I then removed the eddy board from the bracket and indeed it was about ONE millimeter out of place. The yellow glue was intact. I then saw (on the opposite side of the print head) where that ribbon cable begins that it was also not seated correctly.
SHUT OFF THE MACHINE, if you don’t and you cross signal paths when you are moving the ribbon cable around you’ll hear the fan turn on and then the machine reboots. I’ve not noticed any damage from this but best not to temp fate.
Using a pair of tweezers i was able to re-seat both ends. You’ll have to remove the yellow glue.
Push the ribbon cable in and close the latch.
Now you have options. But first understand what’s causing this. The settings of your printer control the G-Forces that the print head feels. The faster you print the more that ribbon cable wants to come unseated.
Option1: Take some paper and wedge it in between the top of the ribbon cable and the latch and then close the latch. You can break the latch if you are not careful. This is a low end fix because you can always turn up the G-forces enough to unseat the cable over time.
Option2: Hot glue gun. Be sure to use a glue gun that supports HIGH TEMP glue sticks and get a high temp clue stick to use. Let that baby heat right up to hot as hell before you take those tweezers and paint on the glue. Put the glue partially on the ribbon cable itself and then drag that blob on top of the latch and little bit past it.
I did this last week but I’ve not tested it yet. Others have had success with the hot glue. The hot glue melts around 175 to 230C. it should hold.
