Flow Rate Calibration YOLO test missing Archimedean pattern
I saw in the Orca slicer release notes that the Flow Rate test YOLO now uses Archimedean as the pattern. However I am running 2.3.0.4 which was released after it was made a part of ORCA slicer. I was trying to confirm if my install is corrupt or if that feature is just not included in the SOVOLSLICER fork of ORCA.
Forks are usually old…sometimes by years.
You will have to download a full version of Orca Slicer.
Also, I don’t know if that version you started is a type-o or not.
Orca Stable is 2.3.0, the newest Beta from 9/19/25 is 2.3.1
Thanks for the reply, I may not have worded it clearly. The version that I mentioned is my SOVOLSLICER version 2.3.0.4. I’ve seen references to the Archimedean Pattern going back to late 2024. This was released in Orca 2.3.0 flow rate calib · SoftFever/OrcaSlicer Wiki · GitHub
Sovol Slicer is a forked version of Orca, the version number doesn’t matter.
Sovol started using Orca with the release of the SV08 at the end of May 2024.
With that said, most likely is a version of Orca from 2023.
You will need to download the real Orca & move the profile over just like you did for whatever printer you are using..SV08, ACE, ACE Plus, Zero & MAX.
Download: Orca Slicer
