First issue with sv06 Plus
Does anyone know why this is happening?
When my print finishes and the Y axis moves forward to reveal the print, the bed or the bearing mount slams into the frame.
If i move the Y axis to its maximum it only reads as moving to 290 not 300
The X axis moves all the way to 300.
By the way, so far every print has turned out amazing.
Is the bed’s cable free ?
Check that the cable does not get caught in the frame.
Yup that kinda what it was.
I had the printer to close to the wall, so when it would home the cable support i printed would hit the wall then when the bed moved forward it was basically 10mm off
My bad, again:)
