Filament Sensors reversed?
I have the filament sensors plugged in per the instructions but they are reversed according to the control pad reactions. The obvious answer is to swap the cables on top but, one just wont reach. I guess I could just feed the filament through the sensor on the opposite side? Then the filaments would be crossing. The cables could be switched at the control board? I really don’t want to tear this brand new printer apart to find out.
Any ideas?
If you don’t like to unscrew the 8 screws of the bottom cabinet iot swap the sensor plugs you could swap the sensor pin settings & recompile your firmware…
Porque dices que están al revés ?
Con el firmware de boerjn se soluciona ?
