Error 73 and “Exception in Hotend_fan”
After using some different macros and going back to the stock ones, my printer is continually crashing with either Error 73 or “Exception in Hotend_fan”. I’ve factory reset it after getting this error repeatedly and it cannot get past the calibration stage without crashing.
Help in how to solve this issue is greatly appreciated.
Have you tried to flash the last firmware?
I am on the most recent firmware according to the screen:
1.4.7
2025-5-20
Yes but who knows? A corrupt firmware?
I asked it to install again but it says I am on the latest. Is there a way to force an update? I am well-experienced in Linux and doing stuff via the command line.
I don’t own zero but have you tried to force it with adapter?
I have not done that but having mainlined my SV08 I could try that.
@Lion could you help him?
I don’t want to make a fatal mistake.
I’m not exactly sure about the error…have you had a clog or removed the toolhead lately..??
It’s possible that a loose plug on the toolhead board is causing your issues.
It’s also possible that your reset didn’t clean out your macros, do you have a backup file from before you made the changes..??
@Liberty4Ever
@cardoc
No clog recently but I cannot heat up the hot end to unload filament now due to it crashing if I try and heat it up.
I kept all my old macro files and went back to what I was using before
Check the wires/plugs like I suggested..if that doesn’t fix it..my only guess would be a macro issue.
I don’t have a Zero so I’m unable to verify this…
The version of printer.cfg on github contains the following:
[heater_fan hotend_fan]
pin: extruder_mcu:PA6
max_power: 1.0
cycle_time: 0.015
kick_start_time: 0.5
heater: extruder
heater_temp: 45
tachometer_pin: extruder_mcu:PA1
tachometer_ppr: 1
tachometer_poll_interval: 0.0013
None of my printers have tach feedback on the hotend fan but I assume that the fan is not spinning up OR the tach signal isn’t valid. Check the plugs at the toolhead board.
One diagnostic technique would be to comment out the 3 tachometer lines. Should allow normal operation but the operator is responsible for verifying the fan is working.
I posted something similar in the ACE forum, but wasn’t sure it was relevant or not.
But you thought the same, so I will post it now.
Commenting out the tachometer section in my printer.cfg appears to have made it functional again but I worry about run-on effects from doing that…
I did the following after modifying my printer.cfg:
  • did a PID tuning
  • did resonance testing
  • doublechecked the values in my printer.cfg with what is up on Github for the Zero
  • did a power cycle
I then tried heating up the extruder and it heated up to 250C with no problems and no crashes. I am not sure what caused the issue but so far it appears to be working okay.
I appreciate everyone’s help.
