As the title says, I’m looking for a compatible thermistor that can go to 315C. I’ve long since upgraded the hot end to the bi-metal heatbreak and hardened steel nozzles, but the thermistor only goes to 293 C. Would be nice to be able to properly PID tune it and go to 300 C. So is there a compatible thermistor for it?
I suggest you ask @Bjoern
I’m rather hoping he’ll show up here ![]()
If you want a particular person to answer your question, call them with their name with an @.
Hi again,
I don’t know. Looking up for a thermistor model with a compatible diameter should not be that big issue. Adjusting the thermistor type in the Marlin firmware should be easy, too.
/R
Björn
