Ebrog
August 11, 2023, 2:22pm
1
My print temperatures were not being updated from 195° when different materials were selected. Looks like Cura 5.4.0 has a bug in its SV06 profile. Here’s instructions to fix:
opened 09:12PM - 10 Jul 23 UTC
closed 12:12PM - 29 Nov 23 UTC
Type: Discussion
Status: Under Investigation
### Cura Version
5.4.0
### Operating System
MacOS Ventura
### Printer
Sovol… SV06 Plus
### Reproduction steps
Did a complete fresh installation on my Mac and found out, that the predefined Material Temperatures are not used within Cura. Cura always uses the 195°C no matter which material I selected.
Used the new SV06 Plus profile, but tested it with the old profile, same behavior.
Didnt had any issued in previous Cura versions on my Mac.
I sliced a model just to see, if the print temp in background are correct, only the view in Cura wrong, but that wasn't the case, the 195° are finale in the G-Code.
Looks like there is an overriding problem of the "basic" 195° print temp, because the bed temp is changing when I select a different material, only print temp will stay at 195°.
### Actual results
Screenshots from UI attached, Print Temps from different material is not imported at all
### Expected results
Print Temps changing with selecting a Material
### Add your .zip and screenshots here ⬇️
[Printtemps.3mf.zip](https://github.com/Ultimaker/Cura/files/12008562/Printtemps.3mf.zip)
Thanks for that- did you have any luck saving the file? I get a message that I don"t have permission to save it after I update it. I tried running as admin and I get the same message.
Ebrog
September 16, 2023, 2:08pm
3
I didn’t have any problems saving it. Maybe restart the computer and edit/save the file first thing before running Cura.
