I ordered a heating block for the SV06. This one arrived today.
But the heatbreak was screwed into the aluminum block and broke off during transport.
I can’t get the remnants of the heatbreak out of the aluminum block. Everything is glued.
From the whole heat block set I can only use the nozzle and the silicone tube.
Everything else is glued and the new broken heatbreak is in the aluminum block.
The heater and thermistor is also glued into the aluminum block
