I bought the Sovol Zero two weeks ago and finally got around to setting it up. However, when I try to home it through the web UI the Z axis keeps going up indefinitely and I have to emergency stop the printer. This happened both times I tried to home it.
The bed and printhead seem to be sturdy and undamaged (so far). After checking the manual more thoroughly I realized I had to do calibration via the tiny knob-screen first. I did that and now homing via the web UI works properly.
Please, add a check and/or make it more prominent a first calibration is absolutely required. The machine appears undamaged (though I need to do a proper inspection) so kudos for the sturdy construction.
