Bed mesh height calibration issue
My new printer has a problem with bed leveling. When I unboxed it, the print bed was lower in the center by default. I was able to mostly correct it by raising the four center mounting screws (I added four 1 mm spacers).
However, the rear side along the Y-axis is still not level, and I don’t know how to adjust it. If I lower the two rear corner screws to level the corners, the rear center sinks down again.
Is the bed itself warped? Is there another way to adjust it?
I noticed there are four wheels with screws underneath the bed. Can these be used for adjustment? They are closer to the center of the bed, so I assume they won’t help much with the rear Y-axis issue.
Your bed doesn’t look that warped.
Mine is similar to yours. Since this printer levels itself with every print, the correction will be made automatically.
Thank you for your response. I took the time to fix these misalignments using tape.
