Well, i probably just destroyed my bed (SV08)
So, i messed up and forgot to replace the bed sheet when starting a print. The nozzle dug into the bed and created a dimple. Can I at least continue printing until I can get a replacement? Or should I replace it right away? Thanks!
A dimple in the magnetic bed..??
The PEI sheet should cover that ok.
Yeah, I guess I kind of panic posted, I realized it’s just the magnetic layer after posting lol.
Put the build plate on and run a bed mesh. If you get a high spot at the gouge attempt to flatten the gouge with pressure or abrasion. If you have a low spot build it up with layers of tape, thin kapton tape works well for this.
Thanks for the advice!
