I noticed that the control of the SV06 ACE Plus has two USB ports. I know that you can load file via USB, but do these ports support other functions? USB wired ethernet adapter? Additional Webcam?
(sorry if this is a newb question)
TIA
There’s no reason for this. I can’t say exactly what’s possible with each USB port. The main issue is finding the right drivers for Linux. USB storage or an additional camera are common uses.
I’m old school and generally prefer hardwired connections unless a device is portable.
Not a big deal at all, just curious
Also LED Light kits.
I would imagine most USB ethernet adapters would work. I personally am using it to power an LED light.
