Upload vs Upload and Print
Been using my New SV 06 Ace for about a month now. I had no issues either using Upload to send a file to the printer, and then be able to access that file via the screen on the printer. I was also able to just use Upload and Print. Both ways worked, although the Upload and Print did not always save the file on the screen on the printer.
Now, if I Upload, Orca says it is complete, but nothing shows up on the screen on the printer, so I cannot select it to print. If I choose Upload and Print, then it starts printing.
Am I doing something wrong, or is there a setting I may have screwed up somewhere. I did check, and the software OTA update is current on the printer.
How many “jobs” are saved to the printer? Memory space is limited and finding a new one among a bunch of others is problematic.
Go to the device tab in Orca and then to the history and (download if you want then) delete all the old “jobs”
You can also “start print” on a stored file from the web interface.
There are 2 parts to the screen.
Local: Upload & Print
USB: Upload (also Gcode if you use a computer).
Local will fill up after a certain number of files, but it should give you an error message.
Thanks for the inputs. I checked the Local screen,and only had 12 files there. Previously, I had approx 30 there, so I believe it can hold a few more. I checked the Device Tab in Orca, looking at History, and it showed 1-99 of 99 files! That looked suspicious, like 99 files was the max allowed. I deleted all of the history ( didn’t need it), and sure enough, I was able to now upload files to the printer . That I believe fixed the issue. Now I just have to watch the history and clear it out periodically.
Thanks!
