SV08 Max Enclosure glass panel inserts
Hi, I was wondering if anyone has an STL file for the plastic washers/inserts for the enclosure’s glass panels. I’ve lost one :slight_smile:
I’m not sure if that part is here SV08 Enclosure STL , but you could email info@sovol3d.com and ask them for a replacement.
I don’t have a model but if you have accurate dimensions you could build one right in Orca:
  1. Add primitive, cylinder, scale to length/diameter of the shoulder
  2. Add primitive, cylinder, scale to length/diameter of the body. Use total length, parts will overlap
  3. Assemble
  4. Add negitive part, cylinder, scale to the size of the hole
  5. Assemble
  6. Slice
Cheers for this, didn’t think of using primitives. I was trying to avoid figuring out how to use CAD software for now, but you are correct; it’s a cylinder on top of a disc.
