SV06 mit SKR E3 Mini V3
This file contains common pin mappings for the BIGTREETECH SKR mini
E3 v3.0. To use this config, the firmware should be compiled for the
STM32G0B1 with a “8KiB bootloader” and USB communication.
The “make flash” command does not work on the SKR mini E3. Instead,
after running “make”, copy the generated “out/klipper.bin” file to a
file named “firmware.bin” on an SD card and then restart the SKR
mini E3 with that SD card.
See docs/Config_Reference.md for a description of parameters.
[include mainsail.cfg]
[include gcode_macros.cfg]
[mcu]
serial: /dev/serial/by-id/usb-Klipper_stm32g0b1xx_360052001850344D30363620-if00
[printer]
kinematics: cartesian
max_velocity: 300
max_accel: 3000
max_z_velocity: 5
max_z_accel: 100
[stepper_x]
step_pin: !PB13
dir_pin: PB12
enable_pin: !PB14
microsteps: 16
rotation_distance: 40
endstop_pin: tmc2209_stepper_x:virtual_endstop
position_endstop: 0
position_max: 225
homing_speed: 40
homing_retract_dist: 0
[tmc2209 stepper_x]
uart_pin: PC11
tx_pin: PC10
diag_pin: ^PC0 # Set to MCU pin connected to TMC DIAG pin
uart_address: 0
run_current: 0.860
stealthchop_threshold: 180
sense_resistor: 0.150
interpolate: False
driver_SGTHRS: 82
[stepper_y]
step_pin: PB10
dir_pin: !PB2
enable_pin: !PB11
microsteps: 16
endstop_pin: tmc2209_stepper_y:virtual_endstop
position_endstop: 0
position_max: 225
homing_speed: 40
[tmc2209 stepper_y]
uart_pin: PC11
tx_pin: PC10
diag_pin: ^PC1 # Set to MCU pin connected to TMC DIAG pin
uart_address: 2
run_current: 0.900
interpolate: False
driver_SGTHRS: 82
[stepper_z]
step_pin: PB0
dir_pin: PC5
enable_pin: !PB1
microsteps: 16
endstop_pin: probe:z_virtual_endstop
position_min: -4
position_max: 251
homing_speed: 4
[tmc2209 stepper_z]
uart_pin: PC11
tx_pin: PC10
uart_address: 1
run_current: 0.580
stealthchop_threshold: 40
interpolate: False
[thermistor sovol_thermistor]
temperature1: 25
resistance1: 94162
beta: 4160
[extruder]
max_extrude_only_distance: 100.0
step_pin: PB3
dir_pin: !PB4
enable_pin: !PD1
microsteps: 16
rotation_distance: 4.56
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: PC8
sensor_type: sovol_thermistor
sensor_pin: PA0
#control: pid
#pid_kd: 86.991
#pid_kp: 21.479
#pid_ki: 1.326
min_temp: 0
max_temp: 300
[tmc2209 extruder]
uart_pin: PC11
tx_pin: PC10
uart_address: 3
run_current: 0.550
stealthchop_threshold: 60
interpolate: False
[heater_bed]
heater_pin: PC9
sensor_type: EPCOS 100K B57560G104F
sensor_pin: PC4
#control: pid
#pid_kp: 64.440
#pid_ki: 0.773
#pid_kd: 1343.571
min_temp: 0
max_temp: 130
[fan]
pin: PC6
[controller_fan electronic_enclosure_fan]
pin: PB15
idle_timeout: 60
[heater_fan hotend_fan]
pin: PC7
heater: extruder
heater_temp: 50.0
[probe]
pin: PC14
x_offset: 28
y_offset: -20
#z_offset: 0
samples: 2
samples_tolerance: 0.015
samples_tolerance_retries: 5
[safe_z_home]
home_xy_position: 85,135
z_hop: 10
z_hop_speed: 5
[bed_mesh]
speed: 120
horizontal_move_z: 5
mesh_min: 28, 20
mesh_max: 210, 205
probe_count: 10
algorithm: bicubic
fade_start: 1
fade_end: 10
fade_target: 0
[display]
lcd_type: st7920
cs_pin: PB8
sclk_pin: PB9
sid_pin: PD6
encoder_pins: ^PA10, ^PA9
click_pin: ^!PA15
[output_pin beeper]
pin: PB5
[board_pins]
aliases:
# EXP1 header
EXP1_1=PB5, EXP1_3=PA9, EXP1_5=PA10, EXP1_7=PB8, EXP1_9=,
EXP1_2=PA15, EXP1_4=, EXP1_6=PB9, EXP1_8=PD6, EXP1_10=<5V>
128x64 Full Graphic Creality CR10 / ENDER 3 stockdisplay
This section is used for a Creality “12864” display with a single
ribbon cable between the display’s EXP3 plug and the
micro-controller board’s EXP1 connector.
## <---------------------- SAVE_CONFIG ---------------------->
# DO NOT EDIT THIS BLOCK OR BELOW. The contents are auto-generated.
# [extruder]
## control = pid
# pid_kp = 21.672
## pid_ki = 1.505
# pid_kd = 78.018
# [heater_bed]
## control = pid
# pid_kp = 68.728
## pid_ki = 1.473
# pid_kd = 801.537
# [probe]
## z_offset = 2.150
## [bed_mesh default]
# version = 1
## points =
# 0.276250, 0.188125, 0.094375, 0.035000, -0.005625, -0.043750, -0.071250, -0.090000, -0.096250, -0.094375
## 0.236875, 0.157500, 0.076875, 0.016250, -0.022500, -0.058750, -0.089375, -0.118125, -0.135000, -0.140625
# 0.198750, 0.125000, 0.040000, -0.018750, -0.058125, -0.098125, -0.128125, -0.155625, -0.179375, -0.193125
## 0.203125, 0.141875, 0.054375, -0.003125, -0.049375, -0.088750, -0.123750, -0.155625, -0.180625, -0.201875
# 0.213125, 0.147500, 0.070000, 0.003125, -0.051875, -0.089375, -0.119375, -0.156875, -0.187500, -0.216875
## 0.188750, 0.133125, 0.055625, -0.009375, -0.066250, -0.101875, -0.130625, -0.163125, -0.198750, -0.225625
# 0.218750, 0.164375, 0.087500, 0.028125, -0.016875, -0.056250, -0.091875, -0.128750, -0.155625, -0.187500
## 0.247500, 0.196875, 0.124375, 0.067500, 0.025625, -0.017500, -0.055625, -0.095625, -0.124375, -0.150000
# 0.281250, 0.232500, 0.164375, 0.110625, 0.066250, 0.022500, -0.012500, -0.053750, -0.088750, -0.107500
## 0.326250, 0.271875, 0.198750, 0.139375, 0.090000, 0.046875, 0.015625, -0.016250, -0.040000, -0.050625
# x_count = 10
## y_count = 10
# mesh_x_pps = 2
## mesh_y_pps = 2
# algo = bicubic
## tension = 0.2
# min_x = 28.0
## max_x = 209.97
# min_y = 20.0
#*# max_y = 204.95
