I would like to run Klipper on my SV02. Doing this, I like to use a 2in2out hotend with two different heaters under klipper.
Fortunately, the SV02 board already has 2 connectors built in.
Can someone tell me please the pin assignment of the second thermistor and the second nozzle-heater?
I already figured out, that the first port is:
heater_pin: PB4
And
sensor_pin: PK5
That would be a good question for a Sovol Tech.
info@sovol3d.com
Thanks for the answer.
I already ask the Support. They told me, that Sovol can’t Help me.
I did find this post on Reddit.
It has a GitHub link that might help you.
Thank you very much for your effort. I really appreciate it.![]()
Unfortunately, the link only talks about how to operate the second extruder (except for one user and he doesn’t say anything about the pin assignment).
But I would need to know how to address the second nozzle-heater to be able to set the temperature of the second hotend.
The aim is to be able to print two different materials. For example, PLA at 200°C on the left and ABS at 260°C on the right
Greetings
