I catch myself sometimes that I want to print something but I am too lazy to change the filament, because it’s a manual process.
Does someone have a suggestion for an AMS for the Zero? I do not need mid-print filament swapping, just for changing the filament before printing.
Are you looking for a turnkey solution or a DIY build?
How many rolls do you want “online”?
Haven’t got around to it, but i’ll probs be doing this : SV08 Max / SV Zero Multicolor Toolhead Upgrade by CN3D by Nadir @ CN3D | Download free STL model | Printables.com so that i can cut the filament (never got tip forming). Unfornatly the owner hasn’t yet repilied as ti how easy it is to fit to a zero. I also have loads of steppers around and a free pico so probs will do the 3MS Happy Hare route.
I am open for both.
2 at least (obvious) but also would like 4.
I currently have the Sovol SH02 dryer, would be nice if it’s compatible.
The Zero & SV08 Max use the same toolhead…the normal SV08 does not.
You ever get to doing this? I have the toolhead basically all built but I have several issues/questions regarding it if you did.
Hello, unfornatly not. But came across this beast : GitHub - Vercanti/Hack-Xol: Small form factor toolhead originally designed to fit the Sovol Zero · GitHub Might wait for the new nebula extruder that has a cutter.
