Hello all,
I have had my Sovol SV07 for a few days now and at first everything went perfectly.
The print results were absolutely phenomenally good, the speed anyway. A dream.
Then I didn’t use the printer for a few days. No one has even touched it. Yesterday, when I switched it on and wanted to print a larger kite, there were catastrophic layer shifts.
So I cancelled the kite and tried XYZ-Cube. It looks like a picture glitch, just awful.
All parts of the printer are still fixed, I did not change the printer.cfg. To rule out the possibility that something was wrong with the printer.cfg, I used one from a few days ago, and the result was the same.
The only noticeable thing is that the end stops of X and Y did not trigger from the beginning.
In addition, I got the following error message when moving in the Y direction:
“Move out of range” and then coordinate values.
This appears in the console: “Invalid adxl345 id (got ff vs e5)”.
However, this has been the case from the beginning and I’m not sure if it really has to do with the layershift or not.
I hope someone here can help me, I’m really desperate.
Thank you very much and best regards,
Kor
