06+, klipper as noted, have run the input shaper tuning, have the calibrations for extruder feed (it’s now 100mm for 100mm, it was like, 93), have run flow calibrations for this printer (used the orca flow calibrator, got it down to where it lays nice and doesn’t grind over each previous layer), but no matter what filament I use, nor what print, if it has a flat top, I get an almost basket weave looking top. Instead of straight lines, it looks almost like woven material.
I’m running .2 layers, .4 nozzle, .44(ish) line widths, and pulling out my hair. Has ANYONE run across anything like this?
