hi folks,
i bought the hardened nozzle set and in this set there is a nozzle with 1.00mm diameter.
now i ask me wich settings i need to change in prusaslicer (with this sliceer i got the best results)
i found the point where i can change nozzle diameter.
BUT is that enough?
did i change also the layer high to maybe 1.00? or less?
can i print in same speed as my other prints will do?
does anyone have printed with sv06+ with this nozzle before?
i also have cura installed and adjusted.
tell me whats your ideas about the settings what would you change to print with that fat nozzle?
