New Sovol Zero Profiles
This started out as a bit of an experiment, but works well so I’d thought I share.
The standard Zero Orca profiles are quite generic, so I back-ported configs from a Core One printer, whilst not as fast they’re more suited for quality, and some thought has gone into setting things up.
This gives nozzle sizes 0.2 through to 0.8, various custom layer heights and various speed settings.
You’ll still have to calibrate the profiles, but I made this as a more complete, baseline. Follow the instructions in the repository and you’ll have a new ‘Sovol Zero Redux’ printer type in Orca, this does not replace the original profile, if you want to revert you can just delete the new printer type.
They can be found under Sovol Redux here;
I have found that the Stock Zero profiles are very close to the Stock A1 Mini profiles in Bambu Studio.
But anything new is always welcomed.
Downloaded and installed for testing…
Thanks, please let me know if you find any bugs and what you think of the profiles.
I’ve also been working on some profiles, and posted an issue to your repo, which is really two - a common bug regarding purge line logic, and a request for you to unzip the files so others can PR against them directly. I have some additional improvements queued up once that happens
