I need help.
My sv04 doesn’t return to the home screen when it prints. The bltouch needle doesn’t seem to be working at the moment.
I’m using firmware 1.1.4 that came with the machine.
What should I do?
Hi @Bjoern,
Maybe something for you.
Hello gmbaratella & welcome to forum!
Your problem description seems to be a bit inconsistent: Usually, your SV04 won’t start printing at all without a working CR-Touch sensor. Anyway, that sensor can be tested - the linked thread shows how to do:
Good luck!
Björn
Let me explain better.
I managed to install version 1.14.2, but I couldn’t install the screen.
I would like to receive a file containing the step-by-step instructions, which seem to have an installation.
When I try to print, the file to be printed doesn’t appear when I click on the list.
Only the 16 Leveling points appear on the screen, not 64.
So there is still something to be done, but I don’t know what to do.
Please, if you can help me, it would be great.
Thank you.
Hi again,
you’ll need to install both printer firmware and a matching display software - otherwise your SV04 won’t be a able to work correctly.
I would recommend the latest firmware version instead of v1.14.2 and the latest display software. The installation process is described in my GitHub wiki here and here.
Good luck!
Björn
