Is there a macro for the M600 command for the Sovol Zero somewhere?
I am new to Klipper but want to print some multicolor items with filament change during prints.
I saw that you can go to the layer, where you want the change in the Orcaslicher and then insert an M600 command.
But Klipper needs a macro to give the printer the step by step commands for this case.
Anyone did one for the Zero already?
The stock configuration supports M600. The code is in macro.cfg which is “included” from printer.cfg
Verify your Orca Slicer has
There has been several issues with “machine G-code” for various functions.
