so I use AstroPrint as my slicer but it is not the best and cannot do multicolor I can not do any software that needs downloading because I do this on a Chromebook and this is the only browser-based software that I think is fine but all the good ones require downloading.
I know that IceSL is quite popular but it is too complicated for me.
I prefer software like IdeaMaker or Superslicer.
On the stock SV06 “multicolor” requires manual filament changes. Have you added a multi filament changer to your machine?
IceSL looks to be quite powerful but the web version does not have a profile for the SV06. There are instructions for creating one but it’s not a simple process.
Which slicing engine do you use at Astroprint? It would be easy enough to edit the g-code files once downloaded. Insert M600 (Filament Change) lines at the layers where you want to change color.
