FYI: Bed is ~250W & Hot end is ~40W
As measured at an 120V outlet, and after subtracting the 13W idle, I get:
  • Bed: 287 Watts initially, declining to 218W before throttling back
    • Steady state 120°C is ~35% and 77W
  • Hot End: 57 Watts initially, declining to 38W before throttling back
    • Some of this is the 24V supply
    • Steady state 350°C is ~70% & 27W
If the bed can be prevented from hitting its upper limit, say by adding a recirculating fan, up to 140W could be unlocked for warming up the chamber air & walls.
According to Extruder Hotend Kit for Sovol Zero | Complete High-Temp Nozzle Assembly the hotend is actually 85W, but those on Discord say its 70W measured from the wall, so 65-68W at hottend.
Guess my smart plug isn’t all that accurate…
Don’t you have more accurate tools to measure it?
