Flying Gantry No Good
Hey everyone,
after spending quite some time comparing different platforms for toolchanger projects, I wanted to share an observation that might help others who are considering a similar upgrade.
In short: a flying‑gantry printer like the Sovol SV08 is not the most ideal foundation for a toolhead‑changer conversion.
Here’s why:
1. Additional Z‑axis movement complicates tool swaps
On a flying‑gantry machine, the entire XY gantry moves up and down on four Z‑motors. That means every toolchange routine adds extra vertical motion, extra syncing requirements, and more chances for positional drift. A toolchanger works best on a system where Z stays stable and stationary during swaps — something closer to a Voron 2.4, a BLV MGN Cube, or any fixed‑bed CoreXY.
2. The SV08 bed is still not perfectly flat — even in newer revisions
A reliable toolchanger setup absolutely depends on consistent nozzle height between tools. If the bed has noticeable variations or a natural “dish” shape, the machine has to compensate more aggressively. On the SV08, many users still report that the bed is not as flat as it ideally should be. This makes dialing in precise nozzle offsets for multiple tools much harder than it needs to be.
3. More moving mass = more tuning, more inconsistencies
Because the entire gantry moves in Z, any slight misalignment, racking, or motor desynchronization affects tool docking and undocking. A toolchanger wants a rigid, predictable frame. Flying‑gantry designs just have more variables in play.
Bottom line:
The SV08 is a great printer for many purposes, but as a base for a multi‑toolhead system, it adds complexity where you really want mechanical simplicity and rigidity. If someone truly wants to get into serious toolchanging, a fixed‑gantry CoreXY platform will generally be the better long‑term choice.
Just thought I’d share this for anyone planning ahead — it might save you some frustration down the road.
Cheers!
I don’t understand. The Voron 2.4 is a flying gantry why is it preferred?
Even more, an SV08 is essentially a Voron 2.4…
The only way to really address his concerns is with closed loop steppers or linear motors w/absolute encoders. That’s probably next gen stuff in consumer space, except for the Peopoly machine, hope they work the kinks out in the next rev.
We’re working on INDX now where the tools sit on the gantry itself so no Z movement to pick up the tools. MakerbeamXL 1515 extrusion on the front.
Awesome, ~same setup should work on Max, given the AWD Z and wider belts.
