Does Zero Use Mainline Klipper
Is Zero using same Klipper as Sv08, and if so can it be upgraded to mainline Klipper in the same way?Can display be upgraded to the better larger display that’s available for the Sv08?
People that have one are too busy to post so I’ll share what I know.
If you drill down into the STEP model on Github you’ll find:
That leads me to believe the Zero has the same board as the SV08
That board does have HDMI output so you should be able to run Klipper Screen on lots of different displays.
The code section on Git is mostly empty but does have folders for Mainsail, Klipperscreen, and kiauh.
looking onto printr.cfg shows toolhead is now CANbus. Also the eddy sections
Seem to indicate the “Next-Gen 3.0 Auto-Leveling” use method discussed here. Mainline Klipper has you covered.
Oops:
I do NOT find “contact_probe” in mainline Klipper documentation
