Build plate
Just had this arrive, which I ordered yesterday.
& it fits the Max nicely.
Ordered from Amazon. Didn’t realise, until it arrived, that you also get the magnetic backing plate too.
Going to run a test print shortly, to see how it performs.
Not a full test of the printer’s abilities, but good adhesion & a good bottom surface.
This does remind me of another question I’ve been meaning to ask for awhile. When the printhead parks itself in the front left corner, just before it starts printing, whilst the nozzle comes upto full temperature, as it goes to start the print, the nozzle scrubs the front corner of the plate as it moves toward the print area. Is there something I can change in the config to park the head a mm or two above it’s current position, then get it to drop back down by the same amount to start the print?
I’m assuming that front corner of the bed must be a fraction higher than the rest of the bed, hence it scrubs the nozzle on the plate.
