Belts in replacement parts
May I know the references of the tension belts for these printers ?
I didn’t find them on the wiki or on the SOVOL site for spare parts.
Hi again,
as far as I know, there is no such reference & the SV04 Operation instruction manual is not precise about belt tension.
Searching the web for belt tension frequencies of printers with the same bed size, e.g. the Ender-3 S1 Plus, could help to get better information.
Good luck!
Björn
I’ve read all the manuals on these machines and I can’t find these informations
The X belt of my SV04 has lost several teeth so I would like to make a small stock of tension belts.
I can measure them, but with the references, it would be more accurate.
So @Sovol3d, if you can help me, that would be nice of you.
Regards
If it is the one in the picture, the size is as follows
SV04: X-axis 1193mm Y-axis 1050mm
SV06 PLUS: X-axis 920mm Y-axis 870mm
SV06 ACE: X-axis 785mm Y-axis 735mm
SV04, SV06plus specifications: 2GT-width 5.7mm
SV06ace specifications
X axis: 2GT, width 5.7mm
Y axis: 2GT, width 9mm
Can you also tell us the specifications for the SV06 PLUS ACE? And perhaps what Hz it should be tensioned to?
SV06 PLUS ACE
X-axis: 2GT-width 5.7mm
Y-axis: 2GT-width 9mm
There is no clear standard value available at present, just make sure that the XY axis moves smoothly without obvious lag
