Need help finding a replacement
When turning on my printer today I noticed that the y axis belt couldn’t move all the way back so I tried changing the tension of the y axis and it snapped. How would I go about getting a replacement? what would I be looking for
Have you take a look on the Sovol website ?
If there is not such an item, send them a mail to buy it at info@sovol3d.com
I’ll check again but I checked the website once already and I couldn’t find the part
I can give you these informations :
SV04: X-axis 1193mm Y-axis 1050mm
SV06 PLUS: X-axis 920mm Y-axis 870mm
SV06 ACE: X-axis 785mm Y-axis 735mm
SV04, SV06plus specifications: 2GT-width 5.7mm
SV06ace specifications
X axis: 2GT, width 5.7mm
Y axis: 2GT, width 9mm
Nothing for SV06. I presume it’s the same that for Sv06 plus but not sure. I don’t own such a printer.
I found these two:
