Belt tension Sovol SV 06 Plus
is there an easy to understand method for correctly setting the belts on the SV06 Plus? Many recommend the Prusa-app and determining the Hz number for each belt. However, opinions differ greatly as to which Hz number is the correct one.
I have completely disassembled and reassembled my printer because I have replaced the ball bearings. But now I have a problem with the belt tension which shows on the print pieces.
Thanks for any tips
I just selected the option for the “Original Prusa MK3/S/+” on Prusa’s belt tuner since the SV06 Plus is more or less a MK3+ clone and it’s been working fine for me.
