So there’s this print that I want to do, problem is all plates have AMS, so my question is if I can do the print and if so what will happen when the layer color changes?
https://makerworld.com/en/models/91140-pistachio-bowl-final-version?from=search#profileId-97486
Lion
2
In Orca, once you add the 3mf..remove all the colors except one.
cardoc
3
Thanks Lion worked well
Orca still demanded I edit my layer gcode to home every layer.
I’m stubborn so I
cleared the plate and imported the stl files
Works with the colors still active too.
Lion
4
The code probably had Timelapse on.
