What to do with code m1901
hello @Bjoern
as part of the loading of the new release this morning I have discovered the subject with your page G‐code M1901 ‐ Call RTS display screen directly · Bjoern70/SV04-IDEX-3D-Printer-Mainboard-Source-code Wiki · GitHub
but I did not figure the intent of this command !
can you help ?
my best regards and thank you for continuing the improvements of the firmware
by the way @bjoern I have the same question for m1900 !
please note that your wiki page on the subject on Home · Bjoern70/SV04-IDEX-3D-Printer-Mainboard-Source-code Wiki · GitHub is empty !
Hi again,
thanks for letting me know - the wiki pages should be working again.
GitHub changes the wiki page address once you change the page name. However, each link on the home page needs to be adjusted manually…
To answer your questions: M1900 and M1901 are intended to support print hosts like Octoprint by adding functions to reset display variables & switch display screens directly. I received feed-back about display screen dead-locks from print host users. I don’t use any print host, so I added M1900 & M1901 in order to allow any kind of workaround in print host scripts.
/R
Björn
