SV06 Plus ACE Github repository
Just checking if anyone can share the link to the Github repository for the SV06 Plus ACE.
I screwed up my klipper install, so need to revert back to the original.
Right now, there isn’t one…but it will show here when there is.
Same with the Wiki.
For now you will have to put in a ticket info@sovol3d.com
@sovol3d
The wiki page is superfluous. It only links to the old Orca profiles. The current Orca profiles are available on GitHub. Nothing else about the SV06 Plus ACE is available on GitHub so far.
My problem seemed to fix itself. After making some config changes I was getting an error that it couldn’t connect to the mcu. Restarting Klipper or Firmware didn’t help, rebooting the whole machine didn’t help. But after shutting it off completely and then bringing it back up, everything started working again.
