Hola, con el firmware de Jhon carlson no consigo hacer una pausa en una capa y luego tras agregar una etiqueta nfc continuar.
Con el ultimo firmware de Boerjn funciona ? o algun otro comando gcode que pause y deje continuar ? gracias
Hi luisarnaiz,
my current firmware release should process each gcode M125 & M600 as a print pause. M600 will pause for a filament change procedure, but it can be passed through without the need to remove the current filament.
Good luck
Björn
Eso en tu firmware ? en el de carlson la funcion de posprocesado de cura pause eigth no funciona la pantalla se bloquea y no deja continuar.
You asked about ways to pause printing in my current firmware version. There were several modifications in my firmware releases in order to improve pause processing, therefore the gcodes I mentioned above should do this. Please note that it’s not my concern how Cura converts pauses to gcode statements, If in doubt, I would recommend manually editing the print file with a text editor.
/R
Björn
