Is SV06 All Metal Planetary Direct Drive Extruder Complete?
@sovol3d - I would like to purchase a pair of the SV06 All Metal Planetary Direct Drive Extruder kits so that I can preinstall different nozzles for different job types. This will prevent me from constantly removing and replacing nozzles on my existing Extruder assembly.
Is the kit as supplied a full replacement for the existing assembly? In other words, can I simply unplug the ribbon cable, remove the 3 screws, swap assemblies, replace the screws and the ribbon cable without the need for additional parts?
Tim
Hi @Timpraetor As what’ve I’ve been informed, yes. The kit is a full replacement for the existing assembly that you could simply unplug, swap, and replace without the need for additional parts.
My secondary extruder assembly arrived today, so I can now keep my 0.6 and 0.2 nozzles engaged and just swap tool heads.
Now, just awaiting my SV06 Plus!
Tim
…and now the same question regarding the SV07. When will we be able to buy print heads for the SV07 (I already managed to rip a nozzle within the hotend and had to buy a replacement :frowning: )
