if you have a lot of Gcode files here is a tutorial on how to back up the Comgrow T300.
download the Winscp app the link WinSCP :: Official Site :: Download
download Advanced IP Scanner – Téléchargez un analyseur de réseau gratuit
install both apps on your PC
find your T300 IP address with advanced-ip-scanner
connect T300 with the IP address grab the root user password makerbase.
bravo you are connected to Klipper!
if you have a pi and you have kept the base user: it is in /home/MKS/printer_data/gcodes
otherwise it is in /home//printer_data/gcodes -
for backup you can also copy the printer_data directory with winscp to a USB Key
here is the final procedure (be careful not to manipulate other files at the risk of compromising the proper functioning of Klipper!
I am not responsible if you make a handling mistake; i suggest you take a backup of your EMMC…
Francis
