Firmware t500
Hi has anyone had problems upgrading the firmware on the T500 to the latest version. I have used the EMMC module as per the tutorial but have had problems getting the file from ETCHER to the flash unit , when I did the screen wouldn’t come on, I have checked the ribbon connector for the screen and this looks OK.
Allan
What do you use with etcher to flash the firmware?
Hi
I used a Emmc adapter that I plugged my Emmc module into, then used Etcher to extract the latest file from Sovol but it keeps failing .
use pi imager and custom file to burn the image
