nope just a video presenting, detailed explanation is in github readme.
Do we take out everything on the factory buffer config file, and replace with active filament buffer?
Let me make sure i understand this correctly, the passive that only uses the feeder as a sensor runout and not using the motor at all for helping filament. (Dont really care to do this one)
And the active buffer that you show in your videos, that uses your new logic and new cases to help prevent overheating of motor. (Do want to use this one)
My question is do i replace everything in the buffer config file from sovol factory one. And copy and paste everything you have in your code (minus the passive part)?
You need replace all default code from buffer, and take into account that you need to have good tensioner or filament will slip.
Can i check do i need to print this or i can just use the stock filament buffer and just change the macro? Thanks
And does it resolve the false tangled issue
