Error code list
Error code list that came with printer
Pic 2 not every one got this apparently I didn’t with mine
Thanks, never seen it before.
Do you think you can scan them & upload so users can download & print..??
Did a quick translation in AI and compared images against below. I might of missed something, but over all translation looked clean. Shows a error in the codes as well, see bottom.
SOVOL ZERO — Screen Prompt Codes
No. Knob screen prompt code Reasons and Problems
1 101 x / 101 y / 101 z No trigger on %s after full movement
2 102 Probe triggered prior to movement
3 103 x / 103 y / 103 z Endstop %s still triggered after retract
4 104 x Must home axis first X
5 104 y Must home axis first Y
6 104 z Must home axis first Z
7 105 x Move out of range X
8 105 y Move out of range Y
9 105 z Move out of range Z
10 106 Extrude below minimum temp
11 107 Extrude only move too long
12 108 Move exceeds maximum extrusion
13 109 Pressure probe more than five times
14 110 Exception in chamber_fan
15 111 Invalid lis2dw id
16 112 LDC1612 I2C bus busy or timeout error, please check the connection between the sensor module and the mainboard
17 113 LDC1612 I2C bus error. There may have been internal or external interference during the communication
18 114 Invalid ldc1612 id
19 115 Invalid probe_eddy_current height
20 116 Failed calibration – incomplete sensor data
21 117 Failed calibration – frequency not increasing each step
22 118 Must calibrate probe_eddy_current first
23 119 probe_eddy_current sensor outage
24 120 Unable to obtain probe_eddy_current sensor readings
25 121 probe_eddy_current sensor not in valid range
26 122 Communication timeout during homing
27 123 Eddy current sensor error
28 124 Must home before probe
29 125 Exception in exhaust_fan
SOVOL ZERO — Screen Error Codes
Error codes 1–15
No. Knob screen error code Reasons and Problems
1 1 Multiple unknown error reports
2 2 Shutdown cleared when not shutdown
3 3 sentinel timer called
4 4 Invalid command
5 5 Message encode error
6 6 Command parser error
7 7 config_reset only available when shutdown
8 8 oids already allocated
9 9 Can’t assign oid
10 10 Invalid oid type
11 11 Already finalized
12 12 Invalid move request size
13 13 Move queue overflow
14 14 alloc_chunks failed
15 15 alloc_chunk failed
Error codes 16–53
16 16 update_digital_out not valid with active queue
17 17 Scheduled digital out event will exceed max_duration
18 18 Can not set soft pwm cycle ticks while updates pending
19 19 Missed scheduling of next digital out event
20 20 Can’t reset time when stepper active
21 21 Invalid count parameter
22 22 Stepper too far in past
23 23 Can’t add signal that is already active
24 24 ADC out of range
25 25 Invalid spi config
26 26 I2C Timeout
27 27 I2C START READ NACK
28 28 I2C_START NACK
29 29 I2C NACK
30 30 Scheduled pwm event will exceed max_duration
31 31 Missed scheduling of next hard pwm event
32 32 Invalid buttons retransmit count
33 33 Set button past maximum button count
34 34 Max of 8 buttons
35 35 tmcuart data too large
36 36 Invalid neopixel update command
37 37 Invalid neopixel data_size
38 38 Thermocouple reader fault
39 39 Invalid thermocouple chip type
40 40 angle sensor requires cs pin
41 41 Invalid spi angle chip type
42 42 HX71x gain/channel out of range 1–4
43 43 Not a valid input pin
44 44 Not an output pin
45 45 Not a valid ADC pin
46 46 Rescheduled timer in the past
47 47 Failed to send i2c addr
48 48 Unsupported i2c bus
49 49 Invalid spi bus
50 50 Another CAN node assigned this ID
51 51 Invalid PWM channel
52 52 PWM already programmed at different speed
53 53 Not a valid PWM pin
Error codes 60–73
The printed list skips codes 54 through 59.
54 60 Lost communication with MCU
55 61 Shutdown due to webhooks request
56 62 ADC out of range
57 63 Heater extruder not heating at expected rate
58 64 Heater heater_bed not heating at expected rate
59 65 TMC stepper_x reports error
60 66 TMC stepper_y reports error
61 67 TMC stepper_z reports error
62 68 TMC extruder reports error
63 69 Move queue overflow
64 70 Missed scheduling of next digital out event
65 71 Unable to write tmc spi stepper_x register
66 72 Unable to write tmc spi stepper_x register
67 73 Exception in hotend_fan
Source-sheet oddity: error codes 71 and 72 both say stepper_x in the photographed document. I preserved that duplication exactly rather than guessing what code 72 was intended to say.
