Does anyone else's aux feeder sound like crap?
does anyone else’s aux feeder sound like crap? make a beeerrrrrrttt noise every time it feeds additional filament. I’ve taken it apart and everything looks fine. any help would be great!
I don’t have a Max so I can’t comment on how it sounds. The aux feeder uses a TMC2209 motor driver in UART mode.
[buffer_stepper filament_buffer]
step_pin: buffer_mcu: PA8
dir_pin: buffer_mcu: PA9
enable_pin: !buffer_mcu: PA11
microsteps: 16
rotation_distance: 9.75
velocity: 150
accel: 5000
push_length: 25
full_steps_per_rotation: 200
push_pin: ^buffer_mcu: PB11
[tmc2209 buffer_stepper filament_buffer]
uart_pin: buffer_mcu: PA12
interpolate: True
run_current: 0.9
hold_current: 0.4
sense_resistor: 0.150
uart_address: 3
There are MANY ways to tune the motor for quiet operation. ONE example is:
Or if you prefer you can manually set the parameters.
Motor specifications (90% sure based on motor dimensions measured from Sovol’s .step model of the aux feeder):
its sounds like a duck quacking every time it feeds . when there is no filament in it and you activate it its much less noisy but sounds like a duck quacking every 10 seconds
Mine sounds terrible, too. It’s extremely loud.
I’ve reduced velocity to 50, & accel to 1000 on mine. I’m currently testing it on those settings. It quietens it notably, & isn’t currently causing any issues feed wise.
It’s worth experimenting with those two values.
I replaced mile with a Infinity flow s1, no more noise, filament runout no longer an issue.
The noise of this one is now down to around half, possibly slightly less, of what it was. Reducing those speeds helped. I’ve also removed the grease from the internal gears & lubricated those with wax, as I noted slight gear noise. That’s gone now. Finally, reduced the travel distance of the tube/sleeve from 25mm to 21mm. Noted an occasional noise which suggested that the arm on that was contacting the housing. That’s now sorted. When the printer’s running now, you have to make an effort to hear the filament feeder, rather than it imposing its presence.
This a quick video of it.
Did you have any issues getting the S1 to fully push the filament into the printhead?
couple of years later now, I can confirm these numbers are very good.
I eventually found the best settings were to leave velocity at its default setting.
accel: 5000
Velocity I adjusted to 30.
velocity: 30
Setting accel too low can occasionally lead to the feeder not recognising when filament reaches the extruder. Velocity seems to be very forgiving of its setting, but that setting has most influence on the noise level.
I’m a little confused by this, is 30 the default?
Are you still doing this? Could you share your full settings for the feeder from your config file (in case Sovol changed something between your starting point and mine).
I’ll look through my config & post the relevant section. I can’t remember myself, what the exact settings are, offhand. I did quite a bit of experimenting to find acceptable settings for the noise issue, but without compromising filament loading.
What are the default settings for velocity, accel & push_length in your buffer_stepper.cfg file?
Just found the post which mentions the settings I used.
above, you meant accel, not velocity. I’ve changed just velocity and we’ll see how that goes.
My settings now:
microsteps: 16
#velocity: 150
velocity: 30
accel: 5000
push_length: 25
Aye, I wrote the wrong one of the two. A numpty moment on my part.
