Dear Solvol.I constructed the sv08 max today after purchasding off the official ebay solvol store in australia with enclosure. I am having issues with it. The axis will not go up or dow it will not do the Eddie current detection, it won’t print the bench. The up and down motion won’t work. It has a trigger warning. When you place a metal object under the probe wiring or probe the blue led doesn’t change to red, it just stays blue. It also will not connect to wifi when it is 1m away from the modem router and only connect via ethernet which I did the firmware update. I am in desperate need of assistance as the printer is non functional.Yours Sincerely mark
Send an email to info@sovol3d.com explaining your issues.
