My problem is solved. I had an issue with the sovol version of cura where the z axis wasn’t moving enough, I’m not sure if I messed with the wrong setting or if it came that way but loading someone else’s profile did not fix it and I had to switch over to the main version of cura and then imported someone’s profile as a starting point.
It is possible to get one of these machines out of the box and running your own files in under an hour. I on the other hand took the time before it was together to lube the bearings which I am happy with. There are some profiles floating around > here and elsewhere if you look hard enough. There is a discord that may actually have paid support available. Honestly there’s too many platforms these days, I like decentralization for some things but not for this.
