Community Guru help needed
Hey All,
for those of you that have this beast sorted to the point you can pull the trigger with confidence on an overnite print and know itll be good, I would very much like to know what your stepper currents, and hybrid threshold values are.
TIA
I just posted a little while ago…
SENDING:M503
echo:; Linear Units:
G21 ; (mm)
echo:; Temperature Units:
echo: M149 C ; Units in Celsius
echo:; Filament settings (Disabled):
echo: M200 S0 D1.75
echo:; Steps per unit:
echo: M92 X80.00 Y80.00 Z800.00 E684.00
echo:; Max feedrates (units/s):
echo: M203 X300.00 Y300.00 Z15.00 E120.00
echo:; Max Acceleration (units/s2):
echo: M201 X800.00 Y800.00 Z200.00 E4000.00
echo:; Acceleration (units/s2) (P R T):
echo: M204 P800.00 R800.00 T800.00
echo:; Advanced (B<min_segment_time_us> S<min_feedrate> T<min_travel_feedrate> X<max_x_jerk> Y<max_y_jerk> Z<max_z_jerk> E<max_e_jerk>):
echo: M205 B20000.00 S0.00 T0.00 X5.00 Y5.00 Z0.30 E4.50
echo:; Home offset:
echo: M206 X0.00 Y0.00 Z0.00
echo:; Auto Bed Leveling:
echo: M420 S1 Z20.00 ; Leveling ON
echo: G29 W I0 J0 Z0.71260
echo: G29 W I1 J0 Z0.31385
echo: G29 W I2 J0 Z0.00635
echo: G29 W I3 J0 Z-0.29490
echo: G29 W I4 J0 Z-0.63740
echo: G29 W I0 J1 Z0.79010
echo: G29 W I1 J1 Z0.38260
echo: G29 W I2 J1 Z0.04385
echo: G29 W I3 J1 Z-0.31990
echo: G29 W I4 J1 Z-0.70490
echo: G29 W I0 J2 Z0.80885
echo: G29 W I1 J2 Z0.40510
echo: G29 W I2 J2 Z0.03885
echo: G29 W I3 J2 Z-0.35115
echo: G29 W I4 J2 Z-0.74615
echo: G29 W I0 J3 Z0.77760
echo: G29 W I1 J3 Z0.37260
echo: G29 W I2 J3 Z0.03135
echo: G29 W I3 J3 Z-0.33365
echo: G29 W I4 J3 Z-0.72240
echo: G29 W I0 J4 Z0.71885
echo: G29 W I1 J4 Z0.33760
echo: G29 W I2 J4 Z0.03885
echo: G29 W I3 J4 Z-0.27115
echo: G29 W I4 J4 Z-0.63615
echo:; Material heatup parameters:
echo: M145 S0 H195.00 B60.00 F0
echo: M145 S1 H240.00 B80.00 F0
echo:; Hotend PID:
echo: M301 P24.03 I2.84 D50.79
echo:; Bed PID:
echo:echo: M304 P375.00 I75.00 D1350.00
echo:; User thermistors:
echo: M305 P0 R4700.0 T94162.0 B4160.0 C0.000000000 ; HOTEND 0
echo:; LCD Brightness:
echo: M256 B250
echo:; Power-loss recovery:
echo: M413 S1 ; ON
echo:; Z-Probe Offset:
echo: M851 X25.00 Y-25.00 Z-1.57 ; (mm)
echo:; Stepper driver current:
echo: M906 X820 Y880 Z800
echo: M906 T0 E550
echo:; Hybrid Threshold:
echo: M913 X253 Y253 Z61
echo: M913 T0 E82
echo:; StallGuard threshold:
echo: M914 X88 Y118
echo:; Driver stepping mode:
echo: M569 S1 X Y Z
echo: M569 S1 T0 E
echo:; Linear Advance:
echo: M900 K0.04
echo:; Filament load/unload:
echo: M603 L0.00 U50.00 ; (mm)
echo:; Filament runout sensor:
echo: M412 S1 ; Sensor ON
Exception in thread read thread:
Traceback (most recent call last):
File “printrun\printcore.py”, line 333, in _readline
File “printrun\printcore.py”, line 329, in _readline_nb
File “serial\serialwin32.py”, line 295, in read
