Hello everyone,
I’m opening this thread for those who want to come up with accessories for this printer.
I did basically the same thing, to keep the cats out. After a few days, I found this cover at Amazon and picked one up cheap. It has an LED light inside that can be plugged into the USB port for off/on control. Just cleaned up the work area a bit.
I have that same tent. I love it. I usually keep the front flap wide open since I mostly print with PLA, but I love having the big LED light, so I can actually see what I’m printing.
Hi. Do you use this enclosure also for printing with ABS/ASA? What inside temperature ro you use? Is it ok for mainboard and power supply being in the same heated enclosure? Thanks
I don’t print in ABS, only in ASA, and with this enclosure, it works well.
When the temperature is too low, I use this to reach 30°C:
https://a.aliexpress.com/_EwVRgMA
So far, I haven’t had any problems with this enclosure.
