I’ve just created an account and noticed a few annoyances right off the bat.
You can’t manually set your avatarand the avatar assigned to you by default looks like some AI-generated slop- I figured out how to set the avatar, but it is very non-intuitive (the interface does not visually show you can actually do it while in edit mode) and the cropping utility for selecting an avatar kinda…. sucks.
- The default avatar still looks like AI slop
- Accounts are required to have a first and last name (weird)
- The info box for “reupload of another model” mentions Prusameters, which gives me the ick and makes me think the site is being scraped from Printables
- A lot of the design decisions look like you’re trying to copy Printables, but if that’s the case then why wouldn’t I just use Printables?
- No dark mode
- No import functionality
- No 3D preview functionality for uploaded models
- The title of the page is stuck as whatever the last model you looked at is (eg. when you view a model then go to the homepage or your user profile page, the page/tab title remains whatever model you were looking at)
- Clicking on “creator center” in your profile brings you to the model upload page(???)
- The image upload utility is very bad (vue-img-cutter) and absolutely murders image quality
- The text editor for the model descriptions is awful
- Pasting contents does not preserve formatting
- Trying to select text and change its style or paragraph formatting, only the first line is affected
- Very little WYSIWYG functionality (you can’t even use formatting tags– you just have to set the formatting and pray it works)
- Can’t embed images, but can embed videos??
- A lot of the UI text is in Chinese, including font families
- Links are not distinct at all and don’t appear to be links unless you hover over them with your mouse
- A lot of really weird newline handling
- Setting a model license doesn’t seem to persist very long– any change elsewhere and it clears your selection
- Image quality of the cover photo is atrocious
- Why are the images appended to the description on the page?
- Small headline description text is just truncated from the description
- Your email address being placed under your username when you click your avatar in the corner is super weird and feels like an infosec hazard
- Editing an existing upload can only be done from your “uploads” page and can’t be done from the model page itself
Editing the cover photo seems to hang on “uploading” as if it’s trying to re-upload everything?
Editing appears to not work at all, see error message
- The image carousel stretches all images to 4:3
I’m sure I’ll find more but I’m doing other stuff so I can’t dedicate more time to this.
