Hey everyone,
I’m Joseph, the creator behind Killa_Prints (YouTube Channel), and I’m putting my hat in the ring for the Sovol Brand Ambassador Program.
About Me & The Channel
I’ve spent decades working in aviation, where disciplined troubleshooting, standard operating procedures, and attention to detail aren’t just good habits, they’re survival skills. Off the flight line, that exact mindset drives my obsession with 3D printing.
I started Killa Prints to cut through the fluff and share the real work behind getting high-performance, open-source machines to run reliably. My content centers around deep-dive calibrations, firmware setups, custom builds, and hands-on modding. Whether I’m building custom printers from scratch or pushing an entry-level bed-slinger to make speed benchies, my goal is always to help fellow makers actually understand why their machines behave the way they do so they can print with total confidence
Featured Sovol Project
- Machine: Haven’t had the chance to work with Sovol yet, but I own 25 different printers from Voron, RatRig, Bambulab, Biqu, Printers for Ants, Maker tech and other custom builds. My most recent completed machine is a Micron 180 from LDO.
- The Project: The Micron build featured Full Motion System Overhaul with custom CNC’d gantry parts, frame rigidity improvements, LED lighting, and Klipper Optimizations
- Firmware & Tuning: Customized Klipper config, dialed-in input shaping, pressure advance, and macro automation.
- Slicer Setup: Tuned OrcaSlicer profiles balancing dimensional accuracy, clean external walls, and practical speeds
- The Problem Solved: This mods eliminated bed variance issues, tightened resonance across high-acceleration travel moves, and documented every step so the community can replicate it.
Why Sovol & What I Bring to the Table
Sovol makes some of the most accessible, modder-friendly platforms out there. You build machines that invite makers to look under the hood, learn, and upgrade, and that’s the sweet spot my audience cares about most.
If selected as an Ambassador, here’s what I’m bringing to the community:
- No-Nonsense Educational Content: High-quality videos covering setup, real-world modding, maintenance routines, and practical troubleshooting that keep users printing instead of scratching their heads.
- Community Engagement: Active support right here on the forum and over in Discord, helping folks dial in their offsets, tune their configs, and navigate common print gremlins.
- Honest, Constructive Technical Feedback: Direct, data-backed feedback from heavy bench testing to help your development team continue refining hardware and software on future iterations.
Appreciate the consideration, and good luck to everyone applying!
Cheers,
Joseph / Killa Prints
